Displays information about ELRP disabled ports.
N/A.
This command displays the results of disabling ports using the configure elrp-client periodic command.
Exclude EAPS ring ports—Whether EAPS ring ports can be excluded.
Excluded Ports—User defined ports that will not be disabled.
Disabled Port—The port that ELRP disabled.
Detected VLAN—The VLAN with looping ELRP PDU(s).
Duration—The configured time to keep the port disabled.
Time Disabled—The time when ELRP disabled the port.
The following example shows ELRP information for disabled ports:
# show elrp disabled-ports Exclude EAPS ring ports : No Exclude VXLAN RTEPs : Yes Exclude inter-VLAN loop ports :No Excluded Ports --------------------------------------------------------------------------- --------------------------------------------------------------------------- Disabled Detected Duration Time Disable Port/Virtual Port Vlan (sec) Disabled Direction -------------------------------------------------------------------------------------------- --------------------------------------------------------------------------------------------
This command was first available in ExtremeXOS 12.4.
The excluded port list was added in ExtremeXOS 12.5.3.
VXLAN remote endpoint exclusion information was added in ExtremeXOS 22.4.
Inter-VLAN loop ports exclusion information was added in ExtremeXOS 30.1.
